Tractor Talk Discussion Forum
Belarus 570 Rear Lug nuts
jimbeck1st
01-10-2004 13:01:13
My Belarus has one lug nut on each rear wheel that is similar to an eyebolt. The nut is manufactured with a large eye that obviously could be used to hook to a chain or cable. I believe someone told me they thought it could be used to hook to a chain or cable and the tractor could pull its self out if it got stuck. Obviously the other end would have to be hooked to a tree or a stationary object. I could understand how that could work if the tractor had a pulley or something to wind the cable or chain but there is nothing. Does anyone know if that is an accurate description of the design and if so, how does it work?
Doug A
01-10-2004 13:10:41
 Re: Belarus 570 Rear Lug nuts in reply to jimbeck1st, 01-10-2004 13:01:13
That bolt is a tiedown for the ocean voyage when they are shipped over here.
wdTom
01-10-2004 17:10:42
 Re: Re: Belarus 570 Rear Lug nuts in reply to Doug A, 01-10-2004 13:10:41
I was going to guess it was an attachment point for lifting with a crane? Your tie down idea sounds good though. I wonder if there is a similar set of eyes somewhere on the front of the tractor too?
jimbeck1st
01-10-2004 19:18:11
 Re: Re: Re: Belarus 570 Rear Lug nuts in reply to wdTom, 01-10-2004 17:10:42
There are no similar tie points in the front.
