Tractor Talk Discussion Forum
5w-30wt in White gas engine??
Michael West
01-10-2004 18:14:25
Hi, I have a 2-63-15 White Mighty Hoe tractor, it is a 1973 model with a Waukashaw gas engine 6 banger. Can I use 5w-30wt oil in it as it is pretty cold here in the northwest. I had 20w-50wt in it from the summer and it would not even turn over at -10 Degrees. Usually it does not get that low but thought I should use a lighter engine oil. Thanks for any replies.
Brokenwrench
01-11-2004 09:20:24
 Re: 5w-30wt in White gas engine?? in reply to Michael West, 01-10-2004 18:14:25
You can use the lighter oil in it in the winter without problems. Just check your oil level more often as it may use some especially if the engine is worn. Switch back to the 20-50 once warm weather gets there again.
