Tractor Talk Discussion Forum
806 Shifting Problems
B B
01-12-2004 03:30:16
The linkage on the range and speed shifters is pretty well shot on my 806. We have adjusted and refitted several times over the years but there is not much left to work with. The tractor has been in continuous use since 1964. Looking for parts on the web I was told by several used parts dealers to switch to a "66 style shifter. (Easier to find and reported to be better??) Has anyone done this before? Any info would be appreciated.
E J
01-12-2004 07:49:39
 Re: 806 Shifting Problems in reply to B B, 01-12-2004 03:30:16
Yes I have changed 706,806,& two 1206s over too 56&66 shifts.The last one I bought from salvage yard was 400.00 with every thing needed.It would help to have a service manual.THese can be wore also pins & linkage rollers,detents which you can buy new still.Cowleing behind fuel tank take off,platte form off ,range deck plate off,left side on trans plate where reverse shifter fork is .Helps to take right steering colume suport off park lever etc.& linkage and use 56 suport instead of 06 other wise you have to do some grinding on the 06 suport,may loose your hyd.out let I ground mine out for the uprigtt shift shaft to fit.Make sure you leave the shift collar on the bottom speed shaft other wise it will fall down in trans.don"t want that.You can cut the cowling to fit the new shift pattern.Also theirs a bushing you will have to drive out up by the shift levers and replace with 56or66 bushing.Clear as mud right you can do it.
wade
01-13-2004 04:07:35
 Re: Re: 806 Shifting Problems in reply to E J, 01-12-2004 07:49:39
EJ, my 966 could definately use some shifter work, has hiniker cab on it. When done with cab on is it just unbolted and tipped up to get at the deck plate and steering support out? Has almost no detents left and gets stuck in 2 gears if you dont know how to shift it.
