Tractor Talk Discussion Forum
1953 Ford 6N Golden Jubilee or NAA
Warren Gile
01-13-2004 14:17:26
Where do I find serial number on one of these tractors mentioned above. Is this a desirable model to restore?
JDK
01-13-2004 20:28:47
 Re: 1953 Ford 6N Golden Jubilee or NAA in reply to Warren Gile, 01-13-2004 14:17:26
1953 Golden Jubilee(Special Noseplate Emblem)
1954>NAA/600 Series(Same tractor)
Jubilee/600 series was replacement for 8N Model.As it was introduced in 53(Fords Golden Anniversary)it was called the Golden Jubilee and had a special "Golden Jubilee"Nosepiece on the front.Production continued with later models of the tractor IDed as 600 or NAA models which did not have the"special nosepiece".Tractor was slightly bigger and more powerful than 8N it replaced,also improved hydraulics.Either version is fully adequate for jobs within it's ability,with the Jubilee being slightly more popular die to the novelty.Serial No should be stamped into the tractor below and slightly to rear of battery on right side.Questions best referred to Ford Board here.
snitkawl
01-14-2004 04:13:04
 Re: Re: 1953 Ford 6N Golden Jubilee or NAA in reply to JDK, 01-13-2004 20:28:47
NAA and 600 are NOT the same tractor. Jubilee and NAA are the same with different emblems. From the engine back the 600 is different.
