Tractor Talk Discussion Forum
165 M-F WEIRD POWER STEERING.. HARD RIGHT-EASY LEF
JOEL CHRISTMAS
01-15-2004 18:03:39
MY M-F 165 POWER STEERING TURNS EASY TO THE LEFT BUT HARD TO THE RIGHT.. SEEMS LIKE NO POWERING STEERING WHEN TURNING TO THE RIGHT!! FLUID OK.. NEED ADJUSTMENT, OR BAD PART?? HELP!!
Zane(Wa)
01-16-2004 18:12:26
 Re: 165 M-F WEIRD POWER STEERING.. HARD RIGHT-EASY in reply to JOEL CHRISTMAS, 01-15-2004 18:03:39
Had a wide front end MF175 with a similar problem when I "unburied" the tractor. Turned out the bushing supporting the pedestal shaft had been worn pretty severe on one side (I don't remember which side of the bushing was the worst). If you support the front and with the tractor running, you may see some play in the pedestal shaft as you turn the steering wheel. It wasn't very difficult to change-out, but getting the correct sized bushing was a PITA without a long wait. 'at's all I know, have fun and stay warm.
Andy Dunford
02-03-2004 21:56:31
 Re: Re: 165 M-F WEIRD POWER STEERING.. HARD RIGHT- in reply to Zane(Wa), 01-16-2004 18:12:26
Email me zane cant find your kit on line thanks
Nominday
01-15-2004 21:55:16
You'll want to read the IT or factory manual on this but there is a balancing adjustment on the steering cylinder area which consists of a small turnbuckle. It's very precise,a tiny move makes a difference. Do read a manual first.
Casey
01-16-2004 07:13:20
 Re: Re: 165 M-F WEIRD POWER STEERING.. HARD RIGHT- in reply to Nominday, 01-15-2004 21:55:16
I had the same problem on my 165 a few years ago. Nomiday's method worked for me.
post
01-15-2004 19:24:48
May want to post this on the MF board where Big Dean resides if you don't get a good answer here. Could be that you have some debris in the steering valve that's connected to the steering wheel or one of the internal parts is sticking. Have you bled the system for air?
