Tractor Talk Discussion Forum
UNSYLED B
Ty
01-18-2004 11:14:14
I have an unstyled b that i just got running. However, I have trouble starting this tractor.It takes 10 or 12 turns of the flywheel to get it to start and I have to choke it each time, even when the engine has ran for an hour.I also noticed that when I put my hand over the top of the exhaust pipe when it is running, I can feel a vacuum and exhaust alternating back and forth (vacuum,exhaust,vacuum,exhaust). The carburetor is from another unstyled b which starts with 1 turn of the flywheel. I just had the valves ground in the head. I would appreciate any help.
Bguy
01-18-2004 18:36:37
 Re: UNSYLED B in reply to Ty, 01-18-2004 11:14:14
Ty, I have found that getting the timing dialed in just right has a big effect on the ease of starting. If you are certain you have a got spark and carb, fine tune your timing.
Dr Crank
01-18-2004 18:52:40
 Re: Re: UNSYLED B in reply to Bguy, 01-18-2004 18:36:37
I had an unstyled b that did exactly the same thing and what it was ,was the fly wheel had been off and was not put on in the right cog thus throwing the timing off.
