Tractor Talk Discussion Forum
F20 split rims
fixerupper
01-18-2004 17:46:27
Last winter I bought a '39 F20 with split rims on the rear. I have heard of rear split rims on some of the early tractors but I have never actually seen any until now. This tractor has the 36" cast centers. Are these rims aftermarket or could they have come from the factory?
Fixerupper
01-19-2004 19:37:36
 Re: F20 split rims in reply to fixerupper, 01-18-2004 17:46:27
Thanks for all of the info. Yes, they do look like they would be very dangerous to work with. Years ago I was in a gas station that had a big dent in the ceiling from a ring that flew off of an uncaged truck tire.
r4etired
01-19-2004 18:59:14
F-20's were with either 28 or 36in rims.In 1938 and 1939 they used a cast wheel on the 36in .these all had the ring lock rims. These were F&H also.
Brandon
01-19-2004 18:08:08
My 1940 Oliver 70 has a set of 36 inch split rims. Both are rusted out and need replaced. I will replace them with normal solid rims if I can. From what I've heard, split rims can blow apart when airing the tires up.
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
Fred Milner
01-19-2004 16:21:06
I don't know if the are factory or not but I have a 1937 F-12 with cast centers and split rims. They are rusted out now. Would have to look and see what size they are.
walter
01-19-2004 07:14:19
I have a '42 I4 with split rims.
fixerupper
01-19-2004 05:13:44
By 'split rims' I mean the kind of rims that we used to see on trucks.You know, the ones with the ring on the outside. I know this tractor isn't the only one sporting them.
goofus fr LA
01-19-2004 06:26:50
 Re: Re: F20 split rims in reply to fixerupper, 01-19-2004 05:13:44
I have been around tractors for a lot of years and never noticed a lock, or split ring rim, also worked at a service station that repaired most of the tires in two counties, and the only split, or lock rings that came in were for trucks and 3/4 ton pickups. They had to be unusual south of the Mason Dixon line. goofus
