Tractor Talk Discussion Forum
Tractor seat re-upholstery
Ol Chief
01-19-2004 10:32:34
I have the seat and back pans removed from my Case 1175 tractor and am looking for a firm or firms to do a professional refit of the foam and seat cover.I ask this question because the fabric is attached to the metal pans by a crimped steel band which appears to be sort of a special fastening process. I also need the attaching slide rails that hold down the entire assembly to the floor.
Red Tom
01-21-2004 12:00:51
 Re: Tractor seat re-upholstery in reply to Ol Chief, 01-19-2004 10:32:34
If you're looking for exact original style recovering try Speer cushion in CO. I've had some done at upholstery shop and they are good but don't usually match the original.
Hooks in Texas
01-20-2004 14:22:48
I had the seat, back, and arms for my JD 2630 recovered a few years back at my local car trim shop for $80. He only had a black vinyl but it was a heavy material that has shown no wear. I didn't think he could cover it because it had an attachment method I didn't understand, but he surprised me. Check with your local car trim shop, they may be able to do more than you think.
Ol Chief
01-20-2004 12:33:40
Hi Tom; Where are you in central Texas.Iam in Fredericksburg,Tx.My phone # is 830 997 8296.I will continue to persue this matter because I need seat repair also on a couple of Minne. Moe.tractors. At the moment the Case is most important seat as it is my principal tillage machine.If you wish call me any evening or post me your phone #. In any event I willkeep you aware of what my successes are.
Tom
01-20-2004 18:58:58
 Re: Re: Tractor seat re-upholstery in reply to Ol Chief , 01-20-2004 12:33:40
Ol Chief,
I am in North Central Texas, near Weatherford. Get down to Fredericksburg once or twice a year to take visitors to the WWII Pacific Museum there. Thanks for your phone number, may call you if you post a solution. I will check out the local auto upholstery shops here and will let you know if I am successful. Regards.
goofus fr L.A.
01-19-2004 10:49:48
Posted by C. Amick on June 10, 2003 at 09:40:54 from (65.199.4.62):
In Reply to: Seat Covers for SC, 511-B posted by Terry Nelson on June 05, 2003 at 09:36:39:
V.B. Tractor Parts sells a nice canvas one for $12 for large pan seats. I have several of them.
Ol chief
01-19-2004 19:05:30
 Re: Re: Tractor seat re-upholstery in reply to goofus fr L.A., 01-19-2004 10:49:48
Thanks for the heads up Goofus I do have a few older tractors that need the style of cushion you refer to.However I need a re-do over the existing seat and back, of sponge and vinyl or strong fabric.This is a very expensive seat with five adjustments. Swivel,spring and hyd. shock absorber,weight adj,and everything but cruise control.Dealer price is astronomical!Cannot afford it.I hope someone else has been there & done that. Help!! Please.
paul
01-19-2004 21:27:15
 Re: Re: Re: Tractor seat re-upholstery in reply to Ol chief , 01-19-2004 19:05:30
My NH dealer sends them out to somewhere. My B-i-L had his little Kubota seat redone like you are saying, think it was $60 or so.
--->Paul
Ol Chief
01-20-2004 05:33:40
 Re: Re: Re: Re: Tractor seat re-upholstery in reply to paul, 01-19-2004 21:27:15
Paul; Thanks for the reply,but I could sure use more detailed information.Can you give me anything more specific.Thanks,John Cooney-Ol Chief
paul
01-20-2004 09:43:25
 Re: Re: Re: Re: Re: Tractor seat re-upholstery in reply to Ol Chief, 01-20-2004 05:33:40
I was gonna look for that, as you could send it direct to the 'nearby' upolstery peron - but I don't know much detail at the moment & my B-i-L is several states away for several weeks....
The dealer is in New Ulm, MN. NH dealer, zip is 56073 you could look them up on NH's dealer locator. Best I can do for the moment.
--->Paul
Tom
01-20-2004 08:53:03
Ol Chief, I am in exactly the same situation with my MF-690, 1983 model. If you find a solution please post back here under seat upholstery subject line. Thanks, Tom in N. Central TX
Ol Chief
01-20-2004 12:18:35
 Re: Re: Re: Re: Re: Re: Tractor seat re-upholstery in reply to Tom, 01-20-2004 08:53:03
Paul ;thanks for your reply,I appreciate the help.I am going to my local upholstery shop but do not think they can deal with the problem due to the lower attachment method.
