Tractor Talk Discussion Forum
international 300
chris
01-21-2004 20:40:45
i am looking to buy ih 300 and would like to find some spec. on this tractor. (weight, horse pwer,...) Any responses would be helpfull
TDK
01-22-2004 19:48:49
 Re: international 300 in reply to chris, 01-21-2004 20:40:45
FARMALL 300: PTO H.P.-37.5 Weight - 4700 lbs.(dry wt.)
INTERNATIONAL 300(UTILITY): PTO H.P.-42.8 Weight - 3400 lbs.(w/ water & fuel) Both versions shared C169 engine & were offered with following options:Torque Amplifier;Power Steering;Hydra Touch w/ Fast-Hitch;Independent PTO; as well as various others. *This info from "International Harvester Tractor Data Book" by Guy Fay.Hope this helps!
paul
01-22-2004 11:09:09
Full sized rowcrop or the small utility version?
Fast hitch or drawbar?
Hydraulics, which kind belly or distributor?
With or without TA?
Belt pulley or not?
Wide front or narrow?
(Lots of options on these...)
I have a full sized row crop wide front 300 with 3 remotes, one running the fast hitch. It's basically a beefed up H with about 34 hp. Slow hyd & a wide turning radius on the wide front would not make it a good loader tractor, but sure is a nice handy tractor for a lot of things. Dad pretty much ran 200 acres with it, did all the planting, cultivating, and much of the plowing & disking with it. I have it on the sqare baler all summer & feed grinder all winter.
--->Paul
