Tractor Talk Discussion Forum
Battery weight
Jason
01-23-2004 18:05:10
Did you know that when you discharge a battery, it gets lighter in weight? When you put the electrons back in by recharging, it gains a little weight. Granted, small and not possible to measure, but, it`s true.
RAB
01-23-2004 23:36:35
 Re: Battery weight in reply to Jason, 01-23-2004 18:05:10
Jason,
Don't be silly. All you have done in recharging is 'moved' the electrons from one plate to the other, - at a higher chemical potential enegy. When you run the battery down the electrons don't go anywhere else, do they?
Even considering Einstein's E=mc2,
the gain in mass for that amount of energy would be infinitessimally small.
In fact, the battery is almost certainly going to get lighter when you just recharge it. Think about it, and come back to me if you can't work it out - and are interested enough for the answer!
Regards, RAB
What's you're point?
01-23-2004 18:36:18
The point is?
The point is ....
01-23-2004 20:39:23
 Re: Re: Battery weight in reply to What's you're point?, 01-23-2004 18:36:18
Whadaya mean what's your point? The point is that you've learned something that you didn't know before. You'll probably be in the local bar tomorrow telling everyone the story that you just bad-mouthed. Be appreciative when someone gives you a little bit of knowledge, it'll go a long way. Just joking, but seriously, I think it's pretty interesting stuff. Meanwhile, did you know that when you add air to your truck tires that the gross weight of your vehicle increases, not much ... but it does increase.
buickanddeere
01-24-2004 05:15:11
 Re: Re: Re: Battery weight in reply to The point is ...., 01-23-2004 20:39:23
The point is Jason doesn't understand the process and believes something a bull shooter told him. The only weight loss would be a wee bit of water in the electrolyte mixture being converted to O2 & H2 and floating away.
RAB
01-24-2004 06:17:29
 Re: Re: Re: Re: Battery weight in reply to buickanddeere, 01-24-2004 05:15:11
Ten out of ten. Yeh, well, I thought it might keep him thinking for a week or two!!!!
MT Pockets
01-24-2004 09:40:11
 Re: Re: Re: Re: Re: Battery weight in reply to RAB, 01-24-2004 06:17:29
Could it be somebody talking about the specific gravity of the electrolyte causing this false notion? I know there are a couple of you who could expound on this subject, if you would please. Thanks MT Pockets.
buickanddeere
01-24-2004 10:36:48
 Re: Re: Re: Re: Re: Re: Battery weight in reply to MT Pockets, 01-24-2004 09:40:11
Extra weight in the electrolyte came from the now lighter plates.
Dale in I'N'
01-24-2004 18:50:49
 Re: Re: Re: Re: Re: Re: Re: Battery weight in reply to buickanddeere , 01-24-2004 10:36:48
No guys, you've got it all wrong. Dead batteries are lighter ( less in mass ) the aliens come and take the energy out of our batts, therefore they are lighter.
Jason
01-25-2004 09:49:15
 Re: Re: Re: Re: Re: Re: Re: Re: Battery weight in reply to Dale in I'N', 01-24-2004 18:50:49
Good one, Dale.
