Tractor Talk Discussion Forum
Loader Advice
Doc
01-26-2004 14:30:46
Hi,
I've got a Du-Al 250, which is a basic loader with PTO pump and tank. I replaced the valves, and I can hear air in the lines when the tractor is off and I lower the loader. I thought the air would bleed off of it's own accord, but do I need to loosen the slip fittings on the hoses and cycle the loader up and down a few times to get the air out?
Got a good deal on the valves, it's great having the loader at the same level in the morning as when I left it last night.
Thanks for all help,
Doc
jhill
01-27-2004 07:48:37
 Re: Loader Advice in reply to Doc, 01-26-2004 14:30:46
Sounds like youve got a leak in the control valves. Probably needs new o-rings.
old
01-26-2004 17:09:34
The air should bleed out just by useing it, any time I have worked on my loader system over a few hours of makeing it do its thing the air came out on its own.
