Tractor Talk Discussion Forum
Bad Gas
Red Tail Hawk
01-27-2004 13:15:47
My friends snow blower was run with bad gas in the tank. Now it run very ruff has to keep choke 3/4 on, runs but still ruff found shelac in bottom of tank and no dout in carb. Boiled card in vinegar for 2hrs. helped some but not enough. Is there a aditive he could add to the gas to disslove shelac in tank and carb. Thanks
Mark
01-28-2004 05:45:42
 Re: Bad Gas in reply to Red Tail Hawk, 01-27-2004 13:15:47
Chem Tool brand carburetor cleaner is the finest thing money can buy. You can get it in spray or pints. Get it at your auto parts store; white can with red lable. I usually use several applications of the spray
Keep off hands; it dries them out big time.....because it degreases and devarnishes carburetors. Also keep away from paint..... it is an excellent paint remover (new or old).
Don't be shy with the compressed air when finishing up and if you can get any of the brass orfices out to clean behind them that will help too.
Mark
Mark
01-28-2004 16:59:23
 Re: Re: Bad Gas in reply to Mark, 01-28-2004 05:45:42
I Lied. The product is Berryman's B-12 Chem Tool.
The can is National colors Red, White, and Blue.
Sorry.
Mark
RED TAIL HAWK
01-28-2004 20:16:31
 Re: Re: Re: Bad Gas in reply to Mark, 01-28-2004 16:59:23
Thanks Mark for the correction.
Mark
01-29-2004 05:36:54
 Re: Re: Re: Re: Bad Gas in reply to RED TAIL HAWK, 01-28-2004 20:16:31
You're Welcome
Randy
01-28-2004 00:24:12
Get some Toluene, aka Toluol. Soak the carb in it. Rinse the tank with it. Then run with a little added to the gas. You can get it at paint stores, and maybe hardware or auto parts stores. DO NOT breathe the fumes, or spill it on your skin. It's bad for you.
old
01-27-2004 15:03:01
Vinegar works well for rust but not for cleaning carbs, you need some thing like CHEM-DIP or some other good carb cleaner
