Tractor Talk Discussion Forum
Another generator question
Dave in S MN
01-28-2004 08:50:06
I noticed there was some discussion on generators dwon a little further. I have a 6-volt cut out system on a B JD that is not showing a charge. I have all new parts including generator, wiring harness, cut out, ammeter, light switch with resistor, and new battery. Can't get it to show a charge. Any thoughts?
-Dave R
Lew
01-28-2004 20:41:00
 Re: Another generator question in reply to Dave in S MN, 01-28-2004 08:50:06
If you go through all of Bob M's steps and then suspect it is the generator, here is a way to test the generator. Loosen the belt so the pulley can freely turn, ground the F terminal and connect the battery to the ARM terminal and ground. The generator should turn like a motor. This is an old "boneyard" trick from when cars had generators, you know, in "good"the old days.
Bob M
01-28-2004 11:46:57
Dave - Here’s a step-by-step that may help you figure out the problem:
1 – Make sure the ammeter is working: Turn on the lights with the engine stopped. The ammeter should indicate discharge. If it does not, either the ammeter is bad or else it is wired up wrong.
2 – Polarize the generator. With the engine stopped and the battery connected, momentarily jumper the BAT and GEN terminals at the cutout. You will get a small spark when contact is made. Soon as you see the spark you have successfully polarized.
3 – Now start the engine and run at ˝ throttle or faster. If the ammeter shows no charge, run a temporary jumper wire from the generator F terminal to the grounded ammeter post. If the ammeter shows charge with the F terminal grounded, either there’s an open circuit in the wiring between the generator F terminal and the light switch or the light switch is not grounded. If the ammeter still shows no charge…
4 – With the engine still running at ˝ speed, connect the BAT and GEN terminals at the cutout with a jumper wire. If the ammeter shows charge with the BAT and GEN terminals jumpered, either the cutout is bad or it is not properly grounded.
5 – If the ammeter STILL indicates no charge after doing the above, problem is in the generator.
Note – If the ammeter is not working and you have an accurate DC voltmeter you can determine whether the generator is charging: Take a voltmeter reading across the battery posts with the engine running at ˝ throttle or faster. A reading higher than 6.6 volts says the generator is working.
Hope this helps!!
hey Bob, I have a questio
01-28-2004 15:33:27
 Re: Re: Another generator question in reply to Bob M, 01-28-2004 11:46:57
If the tractor has a positive ground, do you follow the same procedure that you provided?
I have a tractor with a positive ground. The wiring diagram that I have is satisfactory, but doesn't tell me how the tach should be incorporated into the wiring. Currently the - side of the coil goes to the tach. The diagram says it should go to the switch.
Can you help me?
Bob M
01-28-2004 17:06:21
 Re: Re: Re: Another generator question in reply to hey Bob, I have a questio, 01-28-2004 15:33:27
Procedure I outlined above is the same regardless of ground polarity.
Unfortunately without more info on your tach I cannot offer much help on wiring it up, other than that the tach sensing wire must go onto the coil primarly terminal that's connected to the distributor breaker points. Sorry!
Terry
01-28-2004 09:26:22
Not that familiar with JD. I did have the same problem with IH. My A Farmall would not charge until I removed the switch box from the pedestal
that it was fastened to. I had to clean everything, and make sure the box was grounded.
If you have a poor ground or no ground, you will have problems. This can also happen when you paint a tractor and put things back together.
paul
01-28-2004 09:24:46
Did you polerize the relay (cutout)?
--->Paul
