Tractor Talk Discussion Forum
Rear end out?
Todd in Ohio
01-29-2004 06:01:16
I am new to the vintage tractor hobby, but I grew up on a farm and have been around tractors all my life. I have an opportunity to buy a Allis-Chalmers CA from an old friend of mine. He says that about 15 years ago, when he was still farming full-time, that he "tore the rear end out of it". At that point he was told it would cost more to fix than the tractor was worth, so he just parked it. Two questions for all you experts out there. First, I am planning to use this tractor as a blade/haul firewood/general purpose tractor here on the farm...is it a good general purpose tractor? Second, what would the most common definition of "tore out the rear end" be? What would be involoved in fixing it? My buddy had a bad habit of using his tractors to the limit of their abilities. I think he was haying when he ruined this tractor.
Thanks for all your help.
Eldon (WA)
01-29-2004 07:35:22
 Re: Rear end out? in reply to Todd in Ohio, 01-29-2004 06:01:16
Todd the CA has a "hand clutch" on the rh rear axle that was used to stop tractor movement and still have pto and hydraulics. It is a weak point and was known to slip. A lot of them were bolted up solid or replaced with a lh axle. I have a feeling that this clutch is just shot which will give the same results as a rearend being out.
CA's are a nice little estate tractor with lots of power...if it is a rearend used parts will be easy to find for it. I have a tranny/rearend setting out back myself (3rd gear is out).
