Tractor Talk Discussion Forum
Is there a do it yourself fill kit for tractor ti
Carl
01-29-2004 09:31:49
I would like to fill my own tractor tires. Is there a kit or tool I can buy to do this my self??
MT Pockets
01-29-2004 13:54:58
 Re: Is there a do it yourself fill kit for tracto in reply to Carl, 01-29-2004 09:31:49
Carl, I bought two at NAPA. The one I have now and the one I lost. Steve in Texarkana.
Bob
01-29-2004 10:27:27
You need a fill adapter to connect the valve stem to a garden hose. The fitting also releases air as the water flows into the tire.
Most farm supply stores should have them, or be able to get them overnight.
An old-fashioned brass paddle pump works great to pump the solution into the tire.
VADAVE
01-29-2004 10:01:34
Gemplers has the fill tool in their catalog. Don't remember the cost.
Eldon (WA)
01-29-2004 10:07:58
 Re: Re: Is there a do it yourself fill kit for tr in reply to VADAVE, 01-29-2004 10:01:34
I found the same adapter at the local farm and ranch store for about half Gemplers price.
old
01-29-2004 09:49:13
Theres adaptors to hook up a hose to the valve stem but from there it gets tricky, you can use the old way. By the way this is in a 1935 JD owners manual you take a 55 gallion drum and put it about 5 feet higher then the tire and run your hose down to the stem have a valve on the drum fill it with your fluid and let nature do her thing
