Tractor Talk Discussion Forum
LP HEAD FOR A IH 560 FARMALL IS THERE A DIFFERENC
NATHAN
01-29-2004 17:13:30
IS THERE A DIFFERENCE BETWEEN THE REGULAR GAS HEAD AND THE LP HEAD ON A IH 560 FARMALL. MY CASTING NUMBER IS 367188R FOR THE LP HEAD. IF I PUT THIS ON A REGULAR GAS ENGINE WILL IF MAKE IT HIGHER IN COMPRESSION?
Heat Houser
01-30-2004 15:16:11
 Re: LP HEAD FOR A IH 560 FARMALL IS THERE A DIFFE in reply to NATHAN, 01-29-2004 17:13:30
Heads are the same, the difference between the two were the valves and seats were typically made out of Stellite since there wasn't any lead additive in the LP fuel. The difference in compression was a crown on the top of the pistons away from the valve side. As I recall, the gasser piston was flat. IH also made hi altitude pistons and I suspect that they were simply LP pistons running on Gasoline.
