Tractor Talk Discussion Forum
Re: Repair Rear Tractor Wheel
steve
01-29-2004 18:55:41
i have seen that done if you have good structure around the area. aexamine after sand blasting. it is common to have someout cut out a section and wire feed weld back a plate, maybe 3 or 4 inches square, then cut a hoe for the tube. you can grind down the weld and paint and looks great if you take your time fitting the steel plate.
greg
01-29-2004 19:24:01
 Re: Re: Repair Rear Tractor Wheel in reply to steve, 01-29-2004 18:55:41
I have welded the hole shut , and then gone around the rim 180 degrees and drilled a new hole for the valve stem, deburr the hole and have it mounted up.
Terry H
01-30-2004 06:44:30
 Re: Re: Re: Repair Rear Tractor Wheel in reply to greg, 01-29-2004 19:24:01
Same here. No problems.
Terry H
