Tractor Talk Discussion Forum
Re: Re: JD 2010 Gas - Fluid leaking out of steerin
fasting
01-30-2004 09:25:03
If it's the seal above the front axle on an RU, they usually leak some, but dirt prevents puddles when parked on concrete. This slow leak was a casting flaw, costly to fix 'perfect'. We dropped
the front axle assembly, in winter, planned to correct, but with the seal off center, the labor
was a waste. The new seal improved it some, but
sounds like your leak is elsewhere. Good luck.
