Tractor Talk Discussion Forum
6 speed New Departure transmission
Terry
01-30-2004 12:11:19
Has anyone heard of a transmission like this? I can only find information on 3/4/5 speeds.
Are there any WWII guys out there that drove Dodge
trucks, if so, do you remember such a thing? The New Departure was used in a lot of Dodge trucks.
Thanks for any information you may have.
rickm
01-31-2004 11:12:56
 Re: 6 speed New Departure transmission in reply to Terry, 01-30-2004 12:11:19
I've worked on several New Process, mostly 5-speed trannies, but never heard of a 6 speed.
As far as I know, Fuller made several 8 and 10 speeds (some of the Road Rangers). You might try contacting D Miller @ AntiqueDodgePowerWagons or try contacting Dave Carillo . They'll most likely need a picture rather than a casting number. They've always been real helpful.
Davis In SC
01-30-2004 16:43:25
New Departure/Hyatt is /was a bearing manufacturing co. New Process, a division of Chrysler makes/made Transmissions & transfer cases. Not Positive , but I think they joined with GM to form New Venture. My 2001 Dodge has a 6-speed New Venture transmission, I believe the model is NV5600.
raytasch
01-30-2004 16:37:30
I know there is a New Process transmission.
ray
twopop
01-30-2004 16:29:40
new departure made bearings,dont know if they ever made transmissions.alot of companies made war stuff.
marlowe
01-30-2004 15:55:16
NEW PROCESS was use and is used in dodges never heard of new departure
Eldon (WA)
01-30-2004 16:28:20
 Re: Re: 6 speed New Departure transmission in reply to marlowe, 01-30-2004 15:55:16
I believe New Departure made bearings???
Jim in NC
01-31-2004 05:17:30
 Re: Re: Re: 6 speed New Departure transmission in reply to Eldon (WA), 01-30-2004 16:28:20
all of us that are a little gray remember New Departure as the sweetest coaster brake a bicycle ever had. Of course when you took it apart (as most boys who later became tractor men would have done) all those little brass and steel washers sure were a puzzle to re-assemble.
Paul in Mich
01-31-2004 08:22:50
 Re: Re: Re: Re: 6 speed New Departure transmission in reply to Jim in NC, 01-31-2004 05:17:30
Jim, Being slightly more than a little gray, I do remember the New Departure Coaster brakes on bicycles. I also remember the first time I took one apart at age maybe 7, and the adventure of trying to get it back together right. I did, with lots of cursing seldom uttered by a 7 year old kid, and have been attracted to anything mechanical or greasy ever since.
MT Pockets
01-31-2004 07:23:46
Jim, is that the kind that had the steel ring in it that the tang would break off of, and you had no brakes? You take it apart, bend a new tang up with a pair of pliers, put it back together and go back to sliding the wheel. Steve in Texarkana
