Tractor Talk Discussion Forum
Minni Moline U STD..Weight
Frank
01-31-2004 18:42:14
Can anyone provide an estimated weight including filled rear tires ?
Paul Janke
02-01-2004 08:16:35
 Re: Minni Moline U STD..Weight in reply to Frank, 01-31-2004 18:42:14
Mine is 7000 pounds. I think the front is 2000, the back is 5000. Been a while since I weighed it.
Dan in Wisconsin
02-01-2004 05:05:45
Over at tractortips.com they say the weight of the MM "U" is 5,905 lbs. and has 14-30 rear tires. I can only guess that these would be 14.9-30's and be filled with Calcium Chloride for temperatures to -53 degrees. If that's the case and they are properly filled that would add approximately 600 lbs per rear tire. Should be a ball park figure for you. Hope this helps. Dan
