Tractor Talk Discussion Forum
Compression Question
JKC
02-01-2004 08:37:27
This is probably a gross over-simplification of this question, but here goes: If an antique tractor starts rather easily after sitting for a couple weeks or so (pops right off), does that mean that one can assume it has good compression? I look forward to any responses. Thank you.
i r baboon
02-01-2004 19:44:19
 Re: Compression Question in reply to JKC, 02-01-2004 08:37:27
if its gas tractor, be sure throttle is wide open for compression test, run it till warm, first. be blessed
kyhayman
02-01-2004 16:32:50
I bought a 1410 David Borwn a few years ago. It started great, ran strong, had power to spare. In a hard pull it also had a LOT of blowby, couldnt even see the front of the hood. Othwise almost non existant. I tore the engine down and had the block checked at a machine shop, walls were scored so bad that it had to be cut 20 thousandths, crank was wasted. Had to do a 30 thousandths turn and still had shadows (any DB experts are going to say you cant turn these 30, found that out AFTER I did it). With the walls in that shape it couldnt have had much compression.
RJ Miller
02-01-2004 14:23:32
It makes no sense to judge the power or performance of an engine by how easily it starts. The only real way is to take comprssion readings and compare the difference to each cylinder, also know as a percentage of drop. Rule of thumb is anything over 125psi for gas with a varience of 22psi to the weakest cylinder...Does that help?
Scottf
02-02-2004 07:06:34
 Re: Re: Compression Question in reply to RJ Miller, 02-01-2004 14:23:32
Maybe you were thinking of a gas engine. Judging the compression of a Diesel engine based on how it starts at different temperatures is fairly easy and quit accurate with a little experience. There is a direct relation to how well a diesel engine starts and compression. Obviously, since a diesel engine uses compression to ignite the fuel. And heat. Of course, if it does not start well it there could be something else wrong. But a diesel will not pop off cold with low compression. So you can tell, by the way a Diesel engine starts if the compression is good but necessarily if it is bad.
raytasch
02-01-2004 08:53:24
'Good' being what it is, my comment would be yes. It may not measure perfect as some would like to see but if it starts easy and has good power it is probably at least decent. Caution, an engine can have good compression and still be worn. It could have one or more cylinders down on compression and still start quickly on the strong cylinders. jmho,
ray
