Tractor Talk Discussion Forum
Hydraulic fluid that foams
abane
02-02-2004 08:46:22
I have been using a hydraulic foam that foams after you use it for a short period of time.It's a hydraulic-gear oil combination. Is there a hydraulic fluid out there that doesn't foam and if so what is it?
BIG NORM
02-02-2004 16:01:15
 Re: Hydraulic fluid that foams in reply to abane, 02-02-2004 08:46:22
TRY USEING AMORE EXPENSIVE HYDRO OIL LIKE THE BEST YOU CAN BUY AT YOUR LOCAL JD DEALER
jed
02-02-2004 10:24:43
You have an air leak on the intake or suction side of the system.
RB
02-02-2004 09:52:47
Any approved fluid should not foam unless you have air entering the system. Do you notice any whinning sounds. Gear oil can foam in hyd. systems.
