Tractor Talk Discussion Forum
Conversion to 4 wheel drive
Big Bob
02-03-2004 05:03:21
I have a Massey 50 that is a great tractor. Its only shortcoming is that I sometimes need 4WD for some of the work I do with it. Would it be possible to convert it? I look at the prices of new 4WD (or old ones that I am never sure of) and wonder if it could be done? And if so, is there a compatible 4WD front end? Is this an impractical idea because of transmission issues?
mj
02-03-2004 19:00:04
 Re: Conversion to 4 wheel drive in reply to Big Bob, 02-03-2004 05:03:21
How about hydraulic wheel motors on the front and a tractor powered varible displacement pump for control? You could manually provide the right speed for the 'pull' to get unstuck or whatever....maybe you could, with the right sensors on the tractors' pinion shaft, crankshaft, drive axle, etc., electronically match the pump output to provide the proper front wheel speed or..... ? Let me know what you come up with! :-)
