Tractor Talk Discussion Forum
Wet, heavy, sticky snow!
John51
02-03-2004 17:30:58
We just got 8" of very wet snow in Pennsylvania on top of a foot of powdery snow from last week. I'm having trouble with the new stuff sticking to my snowplows. I use a back blade on a JD2520 and a big plow on a JD4020. I run as fast as I can and with the plows at the maximum angle and the stuff still sticks and builds up. What can I use on the blade to help it flow better?
Thanks for suggestions.
dave mullin canada
02-11-2004 04:01:26
 Re: Wet, heavy, sticky snow! in reply to John51, 02-03-2004 17:30:58
here in eastern canada many of us use diesel fuel in the shouts of our blowers for those heavy'wet....march...storms..seems to work well + is cheap
Harrison
02-03-2004 19:44:24
Try WD40.It was developed for the water repelling.And was used on the atlas rockets,also what they use on the statue of Liberty to protect from the elements so I read.
Terry H
02-03-2004 19:40:01
Haven't had much luck with Slip Plate. Give the blades a coat of wax (Simonize, Turtle Wax, Ski wax or something like that).
Good luck,
Terry H
(about 20" on the ground and more coming tomorrow!)
Hermit
02-03-2004 19:26:53
Some snowplowers here in the U.P. of Michigan bolt a large sheet of smooth, thick plastic onto the plow blade. It's the same type of plastic that the cheap backyard pools are made of. In fact, that's what gets cut up a lot.
Dave from Wis.
02-03-2004 19:11:38
my vote is Graphite paint (slip plate already mentioned is the same thing)
dave
02-03-2004 18:06:51
use wax like for a snowboard
Les...fortunate
02-03-2004 17:47:35
Try PAM.
JD-Tractor
02-03-2004 17:37:28
Get some slip plate from your case IH dealer
snowplow man
02-03-2004 21:16:15
 Re: Re: Wet, heavy, sticky snow! in reply to JD-Tractor, 02-03-2004 17:37:28
I was told at the place I get my plow parts that the paint that Myers plow Co. sells has something in it to make the snow not stick. So it was time to repaint one of my plows last year and I used it. It does seem like the snow doesn't stick like it use to.
MPK
02-04-2004 08:36:06
 Re: Re: Re: Wet, heavy, sticky snow! in reply to snowplow man, 02-03-2004 21:16:15
Another thing that is worth a try is silicone spray. It is a pretty good lubricant.
