Tractor Talk Discussion Forum
john deere 2510
john b
02-08-2004 14:07:50
help putting rear oil seal in i have the tool the seal will not go in the housing
Brokenwrench
02-08-2004 15:43:24
 Re: john deere 2510 in reply to john b, 02-08-2004 14:07:50
To do it properly the pan must be dropped,the seal retainer removed and cleaned.The old seal wear ring removed from the crank,and the crank cleaned. Reinstall the seal retainer with a new gasket loosely. Install the tooling WITHOUT the seal,and draw it into place.This centers the retainer on the crankshaft. Torque the retainer bolts. Remove the tooling, install the seal on the tooling,and press in the seal. Install the pan with new gasket.
steve
02-09-2004 20:26:10
 Re: Re: john deere 2510 in reply to Brokenwrench, 02-08-2004 15:43:24
yougots it all wrong 2510 is a300 series engine seal retainer is back end cover of block the very very early 2510s had a different type of seal and cover and you need to replace both if they are old style
john b
02-10-2004 06:53:30
 Re: Re: Re: john deere 2510 in reply to steve, 02-09-2004 20:26:10
i got all the right parts coming. john deere better ideas change the seals and housing over the years.my jd dealer wanted over 10.000 dollars to overhaul just the 180 cu. gas motor. it cost me 1200.00 dollars to get out of there new shop. they would not take any off bill. thanks
john b
02-08-2004 18:03:18
the installer i have is jt30040a. i donot know sthe oil seal and wear sleeve number which is change over from orginal the installer infro show putting seal on with flywheel housing on.i put seal on with tool it will not fit in housing. did i get wrong seal and do you know seal part no.my part book shows old seal
