Tractor Talk Discussion Forum
6 to 12 volt on M -Farmall ?
John -Iowa
02-11-2004 20:10:48
Put a 12 volt battery in my old M Farmall - left the generator wire off ( 6 volt) but noticed output of generator is 15 volts to 30 volts -low to high RPM (using DC voltage meter-no load) can the old generator be used to charge this battery some way? Its a Delco but does not have a voltage output listed on it. Maybe change to a 12 volt regulator or remove voltage regulator and use a diode.If I should have to use a GM one wire alterintor will it work on a + ground battery ?Will it fit under the hood? Thanks for your help. John Dubuque Iowa
26Red
02-13-2004 08:10:47
 Re: 6 to 12 volt on M -Farmall ? in reply to John -Iowa, 02-11-2004 20:10:48
The generator may have been rewound for 12V already..best to take it to the starter/alternator repair shop...they will have the appropriate regulator you need. You should post this on the farmall board- guys over there have wiring diagrams for the conversion you'd like to do.
jed
02-12-2004 10:19:26
I agree with John H. Also you need to change your lights to 12 volt and you need a resistor on the feed to the points. A GM alternator will work, but you have to flip the old bracket upside down and grind a small piece out of it near the front end. This will allow the alternator to lay against the valve cover pan and the old belt will still work. I have done it several times.
John Iowa
02-12-2004 09:13:38
Can a + ground tractor be changed to a - ground and still let the starter work OK ??? John Dubuque
Jon H
02-12-2004 10:38:22
 Re: Re: 6 to 12 volt on M -Farmall ? in reply to John Iowa, 02-12-2004 09:13:38
Any starter with field coils will run the correct direction when fed from a pos or neg ground system. System polarity only becomes an issue with a permanent magnet field starter as used on small lawn mower/tractor type engines.
Glad someone posted that one wire Delco alternators converted to pos ground are avalible. One thing to consider is that if you install a pos ground alternator on a tractor that must run at a moments notice( driveway cleaner etc), do you have someone that stocks these specialty pos ground alternators or parts? if it fails. the pos ground conversion would need a special regulator,diode trio and rectifier unit. My point is that it might be better to convert the tractor to neg ground so standard,off the shelf parts can be used.
Jon H
02-11-2004 20:47:18
Used to do that on old chevy cars/pickups, use the 6V generator with a 12V regulator. The generator will struggle a bit,but will work on 12V. Regulator life will be a bit shorter because of higher current draw of the 6V generator fields running on 12V. The Delco 1 wire alternator needs neg ground. To convert to neg ground is simple and costs nothing but an hours work. 1 reverse battery connections 2 Reverse connections on the amp guage. 3 reverse primary connections on the coil if battery ignition.
r4etired
02-12-2004 16:17:21
 Re: Re: 6 to 12 volt on M -Farmall ? in reply to Jon H, 02-11-2004 20:47:18
When you have finished the conversion Hope it does't get 30 below. I've broken the bendix gear off. trying to start my M at very cold temps since it's been converted.
marlowe
02-12-2004 04:52:17
you can get the delco one wire with - or + ground i have a 6v + ground on my to-20 ferguson they just made it that way for me
