Tractor Talk Discussion Forum
JD A starter problems...
Taz
02-13-2004 10:49:05
I have had the starter rebuilt, put on new cables, and the starter will not turn. I had the starter checked again and it ran fine.I switched my ground cable to another spot and it will still not turn. The battery is good, what am I doing wrong?
Ron
02-13-2004 18:50:00
 Re: JD A starter problems... in reply to Taz, 02-13-2004 10:49:05
I have had problems with the starter ROD and pivot that presses onto the starter switch button on the starter.. Get under it ( after ya KNOW it is OUT of gear) and either press the starter button ( if ya can push it hard enough), or wrap a piece of baling wire around the part of the lever that pushes onto the starter button (be SURE it is not going to short on anything)...try that, and I bet it starts..!!
old
02-13-2004 11:39:10
Can you put the ground to one of the bolts that hold the starter on, if so that would help. I don't know a lot about that set up, but if it has a soliniod that could also be the problem. But if its just a switch type that could also be what is bad. Just a couple of guess that may help
arthur
02-13-2004 15:05:03
 Re: Re: JD A starter problems... in reply to old, 02-13-2004 11:39:10
does it try ? engine may be stuck.,battery cables may be croeded at battery .turn on lihgts on try starter if lights go out you have a bad connection if they go dim you have a locked up starter or engine if the lights dont change you have a bad start switch or broken wires. post back your find please good luck. arthur
Joe
02-13-2004 18:05:43
 Re: Re: Re: JD A starter problems... in reply to arthur, 02-13-2004 15:05:03
My guess is the cables. Don't know much about the JD's, except driving them, but I can't get bump out of any starter without really good connections.
