Tractor Talk Discussion Forum
TA
JIMMY J
02-21-2004 11:35:44
GUESS MY BRAIN ISN'T IN GEAR, WHAT ARE THEY REFERRING TO IN THE CLASSIFIED'S BY GOOD TA?
I'M SURE I'LL BE EMBARRASED BUT THANKS
JIM
Fawteen
02-21-2004 13:40:37
 Re: TA in reply to JIMMY J, 02-21-2004 11:35:44
As the other fella said, Torque Amplifier. As I understand it, it's a sort of planetary gearset that allows you to pull a lever and go down about half a gear without clutching.
Handy when you're plowing and hit a tough spot, for instance.
DL
02-21-2004 18:08:12
 Re: Re: TA in reply to Fawteen, 02-21-2004 13:40:37
It's a sort of "under drive"... you basically have a dual range of gears to select from ... a high range and a low range. Low range = more torque, less speed.
clint
02-21-2004 11:53:30
torque amplifier
