Tractor Talk Discussion Forum
Any ideas??
Paul (ONT)
02-21-2004 17:39:48
HI I have a wet-sleeve in my IH B-250 engine that won't come out- there's nothing to grab on b/c the bottom flange has broken off.
Any suggestions as how to get this sleeve out??
I'd heard that you could use a welder to crack the sleeve + pull it out, but I wanted to check with someone that has attemped this before I burn the sleeve into the block for good.
Again any ideas??
Thanks alot,
Paul
Fawteen
02-21-2004 18:22:43
 Re: Any ideas?? in reply to Paul (ONT), 02-21-2004 17:39:48
If you weld a bead down the length of the sleeve in three equally spaced spots, chances are it will fall out when it cools. Mine did.
champspa
02-22-2004 16:11:30
 Re: Re: Any ideas?? in reply to Fawteen, 02-21-2004 18:22:43
mine to
