Tractor Talk Discussion Forum
Help!! Massey harris 44
cletus
02-26-2004 03:32:29
Help!!! I need information on how to replace the oil seal on the front of the transmission; there's a shaft coming out of the front of the transmission leading to the clutch.. this shaft is split with two sprocks on it, with a chain around it; one of these shafts has to come out in order to get the oil seal on; there should be a way to do this without splitting the tractor. the tractor is a massey harris 44. thanks cletus kipps
Bob
02-26-2004 07:16:48
 Re: Help!! Massey harris 44 in reply to cletus, 02-26-2004 03:32:29
Locate a Maintenance Manual. Buy it. Read it. Then you'll know a lot of things you won't have to guess or ask about anymore. Good luck..... .....
marlowe
02-26-2004 06:10:55
go to massey page and go back some we just told a guy how to do this
rod
02-26-2004 05:36:20
I have the shop manual send me your an email I can scan the section you need and send it to you.
regards
rod
