Tractor Talk Discussion Forum
welding engine block question
Terry
02-29-2004 13:20:49
Can a person weld a block with a 110 volt wire feed welder? Do they make a special wire for this application?
jeffpapier
03-07-2004 20:34:02
 Re: welding engine block question in reply to Terry, 02-29-2004 13:20:49
to weld a crack in a cast block. you drill a hole in the ends of the crack to keep the crack from spreading. grind a shallow V the lenght of the crack. warm the whole block first, then heat the weld area to a dull red. using a stick welder, weld with a nickle rod, peen the weld to relieve stress. allow the block to cool slowly, two to three hours.
T_Bone
03-01-2004 10:52:56
Hi Terry,
No it won't work as you don't have enough amps.
Do a search on the tool forum for "weld" and read for a few weeks. There's been great info posted about all types of welding.
T_Bone
Bruce
03-01-2004 06:43:53
I don't think so....but go to this site and ask...these guys know all there is know about welding.
http://groups.google.com/groups?hl=en&lr=&ie=UTF-8&group=sci.engr.joining.welding
