Tractor Talk Discussion Forum
Tried electrolysis...have question
Bob Spooner
03-01-2004 04:10:40
So I tried it this weekend, and it works great. However, my battery charger cycles on and off. I can see the bubbles come off of the parts in a burst each time the charger is on. would putting a battery in parralel with the charger make the charger "think" there is a contant load there?
Bob
East Hampton, CT
Buzzman72
03-02-2004 05:08:00
 Re: Tried electrolysis...have question in reply to Bob Spooner, 03-01-2004 04:10:40
But the BIG question is...after electrolysis, is the hair gone FOR GOOD? Or do you have to keep going back?
raytasch
03-01-2004 07:56:31
Bob, I have been doing the electrolysis thing for years. Only time I've ever seen my charger cycle is if I have a short such as two terminal pieces touching. I have used three different chargers each with different current rates. How many amps is your charger showing. Surface areas, strength of solution affect current. ray
Larry from MD
03-01-2004 05:22:00
Normally the charger cycles because it puts out too much too fast.When your electrodes get dirty less current will go through and it will stop cycling.Other ajustments can be made,but someone else should talk about them.
