Tractor Talk Discussion Forum
taking hood off JD A''
jerry
03-01-2004 14:56:53
i need to take the hood off my JD A and the steering shaft has to come out to get the hood off. how do you go about taking the steering shaft out
Budd
03-01-2004 16:52:18
 Re: taking hood off JD A'' in reply to jerry, 03-01-2004 14:56:53
Jerry;
You did not say what year of an A you are working on. I have a 49 A and this is how it comes off. Remove the nose cone (3 bolts) You can them remove the two 1/2" bolts on the front of the steering gear. You will need to remove steering wheel. Then all you need to do is turn the shaft and it will screw out of the box towards the front. Then just slide it out. You can remove the hood by unhooking the generator wires at both ends (generator and amp gage), remove both grill screens, loosen dash, remove gas line, unbolt and it will lift off (lot easyer lift off with two people) Hope this helps BUDD )'';''(
