Tractor Talk Discussion Forum
International Model 434 - Diesel
John
03-03-2004 14:41:56
I have a International Model 434 - Diesel and have taken all the glow plugs out to clean and forgot where the wires go on the glow plugs could someone help me Thanks in Advance John
david val
03-03-2004 22:31:47
 Re: International Model 434 - Diesel in reply to John, 03-03-2004 14:41:56
as mentioned, the current flows through indicator and glow plugs from rear to front to grownd IN SERIES.
david
Warm in Texas
03-03-2004 18:43:31
The wire goes from the glow plug indicator to glow plug 4,3,2,1 then ground. There should be a knerled twist cap to secure the wire to the tope of the glow plug.
Hope this helps.
John
03-03-2004 20:42:29
 Re: Re: International Model 434 - Diesel in reply to Warm in Texas, 03-03-2004 18:43:31
the wire seem to go to ground on the back of all the glow plugs and the centre is the + would you now where I can get a picture of this set up or would you have one that you can send to me I have only 1 + wire going to # 1 how does the power get to the others Thanks for your Time John
