Tractor Talk Discussion Forum
484 CLUTCH PROBLEM
Dale Kite
03-03-2004 20:07:39
I'll try here since no one over at the IH board could help.I have a IH 484 that seems to need a clutch every few years. Tractor sees very little loader work and was used with a round baler only a couple years. The fingers on the pressure plate seem to wear uneven, one barely touched and one completly gone. Tractor was bought new in 85 and now has 2300 hrs. on it. Throwout bearing was shot also.Thanks for any help.
Bernard le mécano
03-04-2004 10:15:17
 Re: 484 CLUTCH PROBLEM in reply to Dale Kite, 03-03-2004 20:07:39
Hi Dale, there is no major problem with engine clutch on those 84 series tractor. Put genuine parts and check for bearing free play (1 1/2) inches on cluth pedal. Don't drive tractor with foot on clutch pedal, the bearing worn and the fingers also. Bernard le mécano Québec Canada
Dale Kite
03-04-2004 18:44:15
 Re: Re: 484 CLUTCH PROBLEM in reply to Bernard le mécano, 03-04-2004 10:15:17
484 IH does not have any free travel between the throw out bearing and pressure plate it rides against it all the time. Only clutch pedal hight adjustment.
JMS/MN
03-03-2004 21:20:37
Alignment problem? Bent fork against the throwout bearing?
