Tractor Talk Discussion Forum
Ester
tlak
03-10-2004 02:24:18
Was told you used ester oil if you convert a R12 system but pag if it was already R134. But if you use ester all the charges and oil charges are pag based. So what is the right oil for a honda accord R12 to R134?
RB
03-10-2004 05:35:01
 Re: Ester in reply to tlak, 03-10-2004 02:24:18
I've always used ester oil on change overs and had very little problems. Even on a compressor change I drain the pag if so filled and use the ester. I spoke to a tech at my supplier and he said ester is fine with new systems too. A good alternative to 134a is Freeze12 which is supposedly 80% R134a, cost is just a little more but you do have to have a license to buy it. I've used F12 for about 2 years on change overs and I like it.
Ben in KY
03-10-2004 08:21:21
 Re: Re: Ester in reply to RB, 03-10-2004 05:35:01
Where do you get Freeze 12 ?
