Tractor Talk Discussion Forum
T.D.9
Dick
03-10-2004 11:24:20
Just Picked up A T.d.9. Starts On gas fine But wont Switch to deisel.Have Bled Line, Replaced filters, & Checked All The Switch Over Mechanism. When i bled the Lines Was A Small Squrit Coming Out. Seemed Like not Much Pressure Coming out Of bleeder hole. Thanks In Advance for any Help.
RAB
03-11-2004 07:41:20
 Re: T.D.9 in reply to Dick, 03-10-2004 11:24:20
Are the valves closing properly? Won't run too well on diesel if still on low compression.
Regards, RAB
dick
03-11-2004 23:36:22
 Re: Re: T.D.9 in reply to RAB, 03-11-2004 07:41:20
Thanks rab, But The Valves are Closing properly. Took The Valve Cover OPff & All Is o.k. I Think Something In Pump is haywire. Thanks Dick
Larry from MD
03-10-2004 14:51:35
Did you check that it was running out of the tank real good.
Dick
03-10-2004 18:55:37
 Re: Re: T.D.9 in reply to Larry from MD, 03-10-2004 14:51:35
Thanks Larry Have A Great Flow from the tank To the Injection Pump. The cat Ran Excellent When Was Parked About 4 Years Ago. can give A Small Either Shot, When i Switch It To Deisel & Runs A Few Revs. Till Either Is Gone. Probably Something Wrong In Pump. I cleaned Sediment Bowl Also. Bled The new Filters. Nice old Td9, A neighbor Gave It to me To restore. Thanks Again
