Tractor Talk Discussion Forum
a-c
chaz
03-10-2004 20:01:37
i bought a model and was told that it was a 'c' and i have found the number on gear box and it starts with a "B"46860 is it a "B" or a "C"
wdTom
03-11-2004 18:31:49
 Re: a-c in reply to chaz, 03-10-2004 20:01:37
A C is somewhat wider than a B, the drawbar will not look like a big horseshoe or U shape as on the B, it will look like a spread open U shape. I think the difference is about 6 inches on each side.
chaz
03-11-2004 06:05:20
thank you rod, it does point down
Rod (NH)
03-10-2004 20:12:56
Hi Chaz,
Well, that serial number indicates a B with that prefix. At least you know it has a B transmission. Take a look at the steering arm that attaches directly to the steering gearbox. If it points up, you likely have a C with a B transmission - a possibility since many parts are interchangeable between the two models. If that arm points down, then you probably have a B and whoever sold it to you was wrong. Take a look at some of the pictures on this site. There should be lots of Bs and Cs in the Allis section of the "tractor photos" area. The link is at the left on this page.
third party image Rod
