Tractor Talk Discussion Forum
John Deere 2940 Oil leak
Buba Lee
03-13-2004 21:18:44
My 1981 JD 2940 leaks oil at the shaft where the 3point lower arms attach. I have changed the seals twice There is no wear on anything it is a loader tractor and rarely use the 3 point. If anyone else has had this problem and fixed it I would sure appreciate knowing what to do. Thanks, Buba Lee
david val
03-14-2004 04:05:21
 Re: John Deere 2940 Oil leak in reply to Buba Lee, 03-13-2004 21:18:44
make sure you get the latest design bushings and seals, check sealing between bushings and holders and between holders and transmission housing. check the load contol shaft for straightness and wear or pitting in the seal area. if you use new style seals make sure the shaft is VERY smooth especially in the end chamfer and that the pin holes have very smooth chamfers (you can sand and lap any sharpness or roughness that you feel with a finger).
david
