Tractor Talk Discussion Forum
3cyl ford
Martin
03-17-2004 03:51:51
I have a 3cyl ford motor in a backhoe it is a 1980 with a 201 CID Diesel, is it possible to change this up to a Cat motor or somthing else without to much trouble.
david val
03-17-2004 10:20:12
 Re: 3cyl ford in reply to Martin, 03-17-2004 03:51:51
the engine is probably a part of the tractor stacture: it bolts to the clutch housing and to the front end in a unique way. it's not practical to fit in any different engine.
david
Mark
03-17-2004 05:43:26
Why?
If it is because yours is worn out, you can do a comprehensive inframe for $1000 including new pistons, rods, all bearings and gaskets and head work including valve guides resurfacing and all.
The Ford 3 cyl is a honey of a machine for simplicity and with a few big bore, long stroke cylinders, the torque is there. Like a johnny pop without the pop.
Besides, everything else already fits and you know it will work together as a system.
My 2c.
Mark
ford 201 3 cylinder
02-03-2005 08:12:57
 Re: Re: 3cyl ford in reply to Mark, 03-17-2004 05:43:26
i am going to replace the head gasket any sugestion or specs for re-tighten the heads bolts
Don Dittmar
03-18-2004 05:28:24
I agree with Mark. You cant begin to understand the can of worms you will open up if you try to do a swap like that. Even if the present engine has a cracked block or some type of failure that would be a cause for replacement, you can still find a short block or rman engine to go in and be a lot cheaper..and it will cut down on the headaches.
Good Luck
Don
