Tractor Talk Discussion Forum
5900 ford tractor
Hershel
03-19-2004 05:37:45
Need to know where and how to check the transmission and hydraulic/rearend lubricant on a 1989, 5900 tractor. A copy of a manual instructions would be a big help.
Flurette Farm
03-20-2004 05:45:59
 Re: 5900 ford tractor in reply to Hershel, 03-19-2004 05:37:45
Hershel, if you can afford the tractor you can afford the operators and service manual. They are availible many places and just cost a few dollars. Get them for safetys sake if not other reason.....
nwb
03-19-2004 15:50:01
My 6600 has a dipstick on the left hand side behind the seat. The transmission, hydraulic and rear end oil are all the same. Use Ford/NH 134 oil.
RickB
03-19-2004 14:33:08
There should be a dipstick just in front of the lefthand rear axle housing.
Mark
03-19-2004 05:49:19
If I were to walk up to your tractor I would look for round covers (about3" dia) with a square area (about 1.5") for the wrench to fit. These covers would be up high on the castings. Probably later on, and with the larger tractors Ford used a common sump for the 3 main functions so you may only find one. You'll know it when you see it because it (they) just look like something you remove and install fluid.
Most gear boxes that run on fluid only have it part way to half way up the housing. So for a level indicator, either there is a dipstick or half way down the side of the housing will be a 3/8 (thereabouts) pipe plug just sitting there screwed into the flat side of the casting. The fill level is when fluid seeps out this hole when you pull the plug on level ground.
My 2c
Mark
