Tractor Talk Discussion Forum
10 ft wide 3 point Ford Disc
Scott Bishop
03-20-2004 18:49:23
I found a 10 ft. 3 pt. Ford disc for sale. I have an 800 series Ford. Will my tractor be able to lift this disc? I currently have a pull behind 8 foot disc that pulls well. Will the 10 foot be too much? I have sandy loam soil.
Thanks
steveormary
03-20-2004 21:00:15
 Re: 10 ft wide 3 point Ford Disc in reply to Scott Bishop, 03-20-2004 18:49:23
Scott,your 800 will lift the disk just fine and will have no prolem pulling it. Use draft control,not position control for the disk.
steve
Scott Bishop
03-21-2004 07:10:14
 Re: Re: 10 ft wide 3 point Ford Disc in reply to steveormary, 03-20-2004 21:00:15
Is my 800 heavier than a 8n? Some of the guys with 8n's say this disc is too heavy. Can a 800 lift more than an 8n?
Thanks.
steveormary
03-21-2004 13:38:19
 Re: Re: Re: 10 ft wide 3 point Ford Disc in reply to Scott Bishop, 03-21-2004 07:10:14
Scott,here is what I come up with from one of my tractor books. The higher hp.rating is from pully or pto and the lower would be drawbar hp. Hope this helps. They are a good solid tractor and if it has LPTO it is better yet. Should hace live hydraulics. wt. hp 8N- 2717# 26.19@ 2000 rpm 21.95@ 1750 rpm
851(800) 48.37-41.54@ 2200 rpm wt.3445#
