Tractor Talk Discussion Forum
Timing IH 706
Kennyp
03-21-2004 13:11:59
How can I check the timing on my friends 706 diesel? This is a early model with the glow plug engine. I see a cover plate on the flywheel, but I see no marks on the injector pump. Engine idles nicly, but loads up on fuel when throtle is opened. Pump looks like recently rebuilt--clean and all seals in place with a "rebuilt" sticker. He just got in quite reasonable at auction.
Ohio Hick
03-21-2004 13:34:21
 Re: Timing IH 706 in reply to Kennyp, 03-21-2004 13:11:59
There is a timing pointer on the crank pulley on a D282.To set the static timing turn the engine till the pointer is on the correct mark (3 degrees on a 560,I'm not sure for a 706)then remove the timing window on the side of the pump(small rectangular cover with 2 screws).There will be 2 horizonal lines one on the pump body and one on the advance ring they should be lined up if it is in time.Hope this helps.
Kennyp
03-21-2004 19:40:31
 Re: Re: Timing IH 706 in reply to Ohio Hick, 03-21-2004 13:34:21
Thanks Ohio, I think I can get it from there.
