Tractor Talk Discussion Forum
stopping oil through back throw breather cap on 74
kenneth m davie
03-22-2004 09:34:04
I need advice on how to swtop oil thro back thru the breather /filler oil cap on my 74 ford lehman osco marine conversion diseal engine. I never can spell diseal. Thanks in advance for your recomendation ken davies
Mike D.
03-22-2004 11:32:41
 Re: stopping oil through back throw breather cap o in reply to kenneth m davies, 03-22-2004 09:34:04
Bad rings?
RAB
03-22-2004 11:18:29
Find out what is causing it first. Then we can help, if the problem is not so obvious that it doesn't require any further advice.
Is it because of too much crank case pressure?
Is it worn out, or broken, on one or more cylinders?
Are the bores glazed from too much light use?
Regards, RAB
