Tractor Talk Discussion Forum
ford 5000
dave
03-23-2004 20:21:07
cant get rear hydraulic cover off.Seems to be a locating pin holding it not sure?does any one know of something i may have over looked?
Catskill Pete
03-24-2004 15:29:24
 Re: ford 5000 in reply to dave, 03-23-2004 20:21:07
Oh does that sound familar. I assume you are refering to the top cover under the seat, if so I'll betcha if you check about halfway back on the right hand side you will find 1 more bolt very well concealed by an up right piece of the casting.
Mark
03-25-2004 06:27:06
 Re: Re: ford 5000 in reply to Catskill Pete, 03-24-2004 15:29:24
Seems I have been there too, now that you mention it. Glad I stopped prying before I broke something and had one more look for "one more bolt".
Mark
Mark
03-24-2004 09:59:14
I don't have a 5 but do have it's little brothers. If you are talking about the cover that the seat mounts to, there is nothing but a big gasket that someone may have put sealer on. The hyd system under that cover is independent to everything in the tractor housing with the exception of the inlet/outlet ports on the side of the housing, the perimeter mounting bolts, and this gasket. And yes, there may be a positioning pin or 2 which may be rusted; but my money would go on a stubborn gasket....been there done that.
Mark
