Tractor Talk Discussion Forum
refilling a propane tractor
Brandon
03-26-2004 10:09:35
I just bought a 1962 MM M5 propane tractor. I had the coop come fill it up but the charged as much for the delivery as the fuel. The house I live in was originally a farm house and there is a large propane tank outside that they used to fuel their tractors with. I looked at the guages on the big tank and it is half full so I figure I can use it to refill my tractor. The question I have is what type of hoses do I need, where can I find them, and what are the proper procedures for doing this.
Thanks in advance.
Brandon
john
03-27-2004 08:47:24
 Re: refilling a propane tractor in reply to Brandon, 03-26-2004 10:09:35
Filling with gasoline isn't dangerous?? I purchased 3 new 25lb tanks a couple of years ago because my old tanks were illegal, not those new tanks are illegal. I think the LP companies have some good lobyist.
U can gravity fill the tank from the big tank by venting off the tractor tank. Be sure you don't fill the tank more than about 3/4 full of liquid. Gas has to have room to expand or you will get to see if the popoff works. Use common sense, don't smoke, rub two sticks together, or anything stupid while you are filling it. Maybe you can be lucky enough to find an oldtimer working for a LP company and ask his advise and get help with the hoses and fittings. The new guys are going to be too wrapped up into the legalities of everything. The old valves are dangerous, they just needed to sell some new ones. There are thousands of 30+ year old tanks in this part of the US still using the "dangerous" and "illegal" valves without a single failer.
Roger
03-26-2004 22:02:12
In several of the posts below, it is stated that the large or 25 cent size valve is illegal. I have been in the LP delivery business for 30 years. I ordered 10 of the vapor relief valves in January. This may be a rumor as a lot of LP dealers do not want to bother with LP tractors or pickups. There are a lot of vehicles in California that are run on LP Gas. Some type of fitting has to be available for them to use. I usually sell 10 to 20 vapor relief valves a year. New customers, some people just can't seem to keep track of them, etc. One of the best things you can do for the vapor relief fitting is to install a 90 degree elbow with a short length of pipe. You can vent the vapor away from the tractor using this set up. I know it is difficult to find a true LP dealer, but keep looking there could be one close to you.
former lp deliveryguy
03-26-2004 18:31:36
Wear clothes that don't generate static electricity when handling the propane. You would be surprised how little of a spark it takes to ignite it.
Kerry
03-26-2004 16:25:54
Brandon, it's not a big deal to fill it from the big tank once you get used to it. You need to be sure the tank has a liquid line (a dip tube to draw liquid from the bottom of the tank) because you can't fill it with vapor.
On warm sunny days, be patient, you may have to leave the vent open for 10 minutes for the pressure to drop enough and let the liquid start flowing. I have one of the big valves I got from the local propane place but I usually just use the little vent screw on top.
The other guys are right, be careful, but it's not really that dangerous if you do it right. I guess I don't need to tell you that you need to make sure nobody is smoking and there are no open flames or sparks around since you're venting raw propane! Also, wear good heavy gloves, it will freeze your skin in a second. When I was a kid and thought I was immortal, we used to freeze cokes with it in about 8-10 seconds.
Don't be surprised when the vapor attracts flies and bees, they'll go away when you turn it off.
You can get the hoses from the propane company, tell them what you want and they'll fix you up with hose, valves, fittings, etc. Check at a few different places, usually you can just have them fill the tractor up for you if you tell them to just stop by when they're in the area so they're not making a special trip.
One more trick - there's a pop-off valve in the tank to prevent leaks from a broken hose. First, turn on the valve at the tank just a little crack to put propane in the hose. Crack the valve at the end of the hose just enough to purge the air out of the hose (otherwise you'll pump it into the tractor's tank), then close it. Screw the hose on to the tractor's fitting, then open the valve at the end of the hose to let gas start flowing. While you're there, open the vent on the tractor to let the vapor out, just unscrew it about 1 or 2 turns, no more. Now open the valve on the tank some more, slowly. If you hear a metallic-sounding click, you opened it too far and the pop-off valve cut it off because you had too much flow. If it does, just turn the tank's valve all the way off then back on slowly - not so far this time!
Watch the vent on top of the tank, when it comes out white (liquid), turn off the valves and close the vent screw. Be patient, it may take a while, especially with the small vent screw. Ask the guys at the propane company about a fitting to put on the vent outlet on the tractor, my guys just gave me a spare one they had but I don't know if they can really sell you one.
Good luck! It's really not as hard as my description sounds. Just be careful, wear heavy gloves, and be patient. Oh, if your big tank is less that about 15% full you won't get much out of it and it will take quite a while to fill up the tractor.
Mark
03-26-2004 19:25:19
 Re: Re: refilling a propane tractor in reply to Kerry, 03-26-2004 16:25:54
Oops, I did forget about purging the hose and the flying insects. Never figured just what there was about it that attracted them. Sulphur?
And yes, the fast fill adapters for the 25 cent piece sized vent is illegal today. That's why I didn't talk about it.
It's beem about 5 years since I had it. Forgot a couple of things.
Mark
FB
03-26-2004 15:25:28
I've seen alot of setups around here. Get the stuff from propane supply place. Sure, it has some danger and won't fill as full as a pump will, but works never the less. Most all the precautions as just the same as with gasoline such as NO SPARKS and such. FB
Paul Janke
03-26-2004 15:22:30
There are hand powered propane pumps available so you don't need to let fumes escape to move the propane. You can also heat the bulk tank or cool the tractor tank to speed the fuel transfer. This can be done by taking advantage of sun and shade or by cooling with water from a garden hose on a warm day.
Mark
03-26-2004 10:56:15
What you need is a propane man who farms (like I had). He sold me the necessary hoses and fittings.
1st. This is very dangerous and you need to realize that you are dealing with an explosive/extreme fire hazard. Never forget that.
2. We have minimums here and if we meet that minimum there is no delivery fee. I used to try to time my tractor fill with the house gas delivery.
3. The truck has a pressurized delivery system. It can cram "liquid" into your tractor's tank. Your "nurse" tank can't do that. i.e. you cannot get as full.
4. The nurse tank has to have a "liquid line". This means that the spigot you are attempting to use has a hose inside the tank that goes to the bottom of the tank. When you open the spigot, the tank pressure forces "liquid" propane up the line and out the hose. Without this line, there is no pipe inside the tank and all you have is fumes (vapor phase). This vapor hole is ok for filling, but not for draining. BTU content is about 91,000 BTU/gallon of LIQUID, not vapors. That's slightly lower than diesel and gasoline in that order.
5. You should be outside,away from all sparks, tractor and all ignition sources off around you and down wind of you. You should have wind at your back to remove the filling fumes from your face so that you can breathe (oxygen, not propane).
6. There is a large fill hole on the side of the tank and one or 2 vent holes. One is the size of a quarter about 1/2 way up or so and the other is much smaller and near the top. The large vent is said to be illegal today so you have to use the small one....takes forever.
7. Propane tank pressure is about 250 psig on a hot summer day with a full tank and almost impossible to measure on a freezing winter day. So your fill rate is very variable. Remember, there is no pump to move the liquid, just this static pressure.
8. Use gloves as expanding propane beats Freon 22 hands down for freezing your fingers off when it expands. Connect the hose to the nurse and tractor fill inlet. The hose should have a shut off valve on one end. This end goes to your tractor's tank. (All your tank has is a spring loaded one way valve that opens when propane pushes against it and closes when it stops.) Open the vent on the tractor tank. Gas will immediately start hissing out. Open the fill valve on the hose at the tractor's tank. Open the nurse valve. It will begin filling and depending upon humidity and temp, you may see a frost line move up the tank which is where your liquid is. The vent is set at about 80% full. Can't go over that as you need room for compression on hot days. When the tank is full, liquid propane will squirt out of the vent hole. Shut off the valves (ALL VALVES)and remove the hoses REMEMBERING THAT THE HOSE IS FULL OF LIQUID AND WHEN YOU LOOSEN THE FROSTY FILL NUT, THERE IS MORE BEHIND, STORED IN THE HOSE.
Now, with all that said, propane was the rage before diesel (according to one of my longtime large scale RED tractor loving buddies). Therefore millions of gallons of propane have done millions of tons of work for humanity and not too many casualties have resulted. You just need to keep things in perspective.
Good Luck
Mark
I sold my tractor (green 4020 96 hp) not because it was propane, but I needed cash to help my son out of trouble.
rickm
03-26-2004 16:26:19
 Re: Re: refilling a propane tractor in reply to Mark, 03-26-2004 10:56:15
Mark, I hope anyone working around lp tractors reads this, especially 'newbies'. You have covered more in two (printed) pages than in the 75 minute training film I watched two months ago from a lp gas ditributing company . I hope you don't mind, but I printed your post and will keep it handy when I get asked the same question out in the field. Many thanks.
Rick
Mark
03-26-2004 19:13:17
 Re: Re: Re: refilling a propane tractor in reply to rickm, 03-26-2004 16:26:19
Any time and this is why I'm here. To give and to receive.
Thank you.
Mark
Prof
03-27-2004 14:12:52
 Re: Re: Re: Re: refilling a propane tractor in reply to Mark, 03-26-2004 19:13:17
Boy, these posts brought back some memories for me of the 60's growing up in West Texas where virtually everyone ran on butane/propane because it was unbelievably (by today's standards) CHEAP! (about $.03/gal). Sure, it can be dangerous if not treated with respect. However, I don't recall hearing of a single mis-hap, even though some people were doing some incredibly stupid things when they first began convering over to LP from gas or kero. For, example, some wise guy discovered that the high-pressure liquid butane from the fill-hose was a great engine cleaner/degreaser and the word of this "innovation" quickly swept through our community. One of our hot-shot neighbors conceived the brilliant idea of using it to "blow-out" the dirt from his tractor radiator and promptle froze and burst it. He, of course, would not own up to what he had done, but it was a bit hard to otherwise explain a freeze-busted radiator in the middle of a hot, West Texas summer!
Mark
03-28-2004 08:09:15
 Re: Re: Re: Re: Re: refilling a propane tractor in reply to Prof, 03-27-2004 14:12:52
Prof,
Small world. This RED big time farmer I mentioned farmed near Abilene. LOL.
He said (as you eluded to) that the local sales force reall ranted and raved about them..... that is until diesel came along and the efficiency and convenience became obvious.
I'm a couple hundred miles east of there and lots of nurse tanks, sitting on rotten tires, still (did) litter some propane dealerships.
Watch, someone is going to want me to put them onto one of these dealerships. Haven't seen any lately that I recall.
Mark
