Tractor Talk Discussion Forum
Golden Jubilee
Dan Quinones
03-27-2004 23:53:11
Does Anyone Know???
My Golden Jubilee has a 134 cubic inch, overhead valve, 4 cylinder inline engine. Can anyone tell me what the engine horsepower is? Also, can anyone tell me what the PTO horsepower is? Also, what's the hydraulic lift capacity?
Sure hope to hear from someone soon.
Thanx A Lot,
Dan
Jim.UT
03-28-2004 16:52:10
 Re: Golden Jubilee in reply to Dan Quinones, 03-27-2004 23:53:11
Your three point lift capacity will be limited to the amount of weight you have on the front of your tractor. In other words, the front wheels will come off the ground long before the lift says "uncle". In the case of my Ford 850 (similar tractor, a little heavier, more hp) that number is about 1000 lbs. That's with bags of cement on a pallet using 3 point pallet forks. If you're using a boom pole, the amount of weight you can lift will be reduced as you go further out on the pole (law of the lever, you know).
Jet9N
03-28-2004 07:55:41
According to "Ford Tractors" by Robert N. Pripps
it has 31 HP @ 2000 RPM.Weight 2510#.
HTH
Jet
BobMo
03-28-2004 06:19:08
Or you could buy a manual and find all kinds of neat stuff..... .....
