Tractor Talk Discussion Forum
Stalling Out
Denny Fjelstad
03-28-2004 06:54:06
I have a 1952 Ford 8N, I had it tuned up middle of last summer since than it ran Great up untill now.It started to lose power than it just quit like I turned off the key.It would nt even fire. So I check for gas,broken or loose wires and such.I took the Dist.Cap off and slide my jack Knife between the points,Than it started to fire up but quit right away. I haul it all the way up to the barn than the Darn thing started.can any one tell me what the problem could be? Thanks
Delbert
03-29-2004 08:06:15
 Re: Stalling Out in reply to Denny Fjelstad, 03-28-2004 06:54:06
Has it been converted to 12 volt could be resistor gone bad.
RAB
03-28-2004 12:35:23
Sounds like it could do with tuning again. A tune-up/service does not last forever and last summer was a long time ago - you could have put on several hundred hours by now!
Regards, RAB
old
03-28-2004 09:35:28
could be a number of things may need points again, about once a year thing, or it could be wireing and or a bad switch. Try hot wireing it if it runs its wireing or the switch
