Tractor Talk Discussion Forum
53 golden jubilee rearend fluid amount
earl garner
03-30-2004 12:12:12
just pulled rt. axle housing to repair loose lift pin. now i sant find out how much fluid to put back in it. they say there's a peep hole bolt on the rt. side. HELP EARL
Jim.UT
03-30-2004 14:14:34
 Re: 53 golden jubilee rearend fluid amount in reply to earl garner, 03-30-2004 12:12:12
From page 6 of the NAA operator's manual:
Capacity of differential = 8.5 quarts.
From page 90 (service schedule):
"Remove differential lubricant level inspection plug. Add gear oil if necessary."
Strangely enough I can't find anything in the manual that shows or describes the exact location of the "level inspection plug". Old's description of it sounds as reasonable as any.
EARL GARNER
03-30-2004 18:34:17
 Re: Re: 53 golden jubilee rearend fluid amount in reply to Jim.UT, 03-30-2004 14:14:34
THIS IS EARL TO SAY THANKS TO JIM.UT. I ONLY HAVE ONE BOOK ON THIS TRACTOR SO FAR, AND IT DONT SAY ANY THING ABOUT FLUID LEVELS. THANKS AGAIN EARL
old
03-30-2004 12:37:04
That bolt is the bottom bolt on the PTO shifter plate
Wayne
03-30-2004 19:49:40
 Re: Re: 53 golden jubilee rearend fluid amount in reply to old, 03-30-2004 12:37:04
The oil that runs out of the bolt hole at the PTO shifter will be hyd oil. (three seperate compartments) Is ther not a 3/8 pipe plug on the rear of the left rear axle housing?
