Tractor Talk Discussion Forum
OT Key from a lock cylinder
Farmer in the D
04-04-2004 20:04:32
third party image
I have an old GM Starter switch that I wanted to put on a tractor. I want to be able to use the ACC side of the switch to operate the lights only. It came out of 65 Malibu. Wasn't it possible to take a number off the cylinder or VIN and have a dealer or locksmith stamp out a key from one of those numbers? Seems to me they could do that back then but mind isn't what it used to be. BTW you know I like to work on my tractors as much as the next guy, but like they say, "all work and no play..." Thanks...Jack
John *.?-!.* cub owner
04-05-2004 14:23:01
 Re: OT Key from a lock cylinder in reply to Farmer in the Dells (WI), 04-04-2004 20:04:32
To operate the lights through the switch you will need to use a relay. The amount of current required by lights can over time, if run directly through the switch burn up the switch, maybe even cause a fire.
DukeWNY
04-05-2004 04:41:05
A 1965 GM product should have a 4 digit code between 8000 and 9499 stamped on it. The code will be stamped INTO the lock, not cast on it. Keyblank is a Curtis B10
john in la
04-04-2004 20:28:52
Yes they could make a key from the VIN # then and still can one car today. The problem is do they still have the key code book for a 65. Things have a way of getting pushed to the back of the pile and lost over that many years.
Road Warrior
04-04-2004 20:23:34
Why not go to the parts store and buy a new switch that comes with 2 keys for around $15?? That'll save getting keys made that may or probably won't fit the switch you have now.
Pitch
04-05-2004 02:51:23
 Re: Re: OT Key from a lock cylinder in reply to Road Warrior, 04-04-2004 20:23:34
Are you sure you need a key for that cylinder? Every old Chev I ever had eventually wore enough so the key wasn't neccessary.
04-05-2004 04:53:59
 Re: Re: Re: OT Key from a lock cylinder in reply to Pitch, 04-05-2004 02:51:23
Will check the code on the cylinder thanks. Will also take the VIN to an older locksmith. Wanted to have an original key so someday I could put it back in the car you see. I should have this one ready for one of my Grandkids. Thanks again for your help
Duke(WNY)
04-05-2004 14:41:43
 Re: Re: Re: Re: OT Key from a lock cylinder in reply to Farmer in the Dells (WI), 04-05-2004 04:53:59
Locksmith will not be able to make a key from the VIN number - you will have to have the code number from the lock. Only the lock code numbers are available to a locksmith. If no lock code is available a locksmith can take the lock apart and make a key for it by reading the tumblers.
